rbmatthews
We always hear that four-stroke outboards are much more fuel efficient that two-strokes, but are they? I have been doing a little bit of research to see how the more modern 2-strokes compare to 4-strokes. I gathered performance data on two engines – a Mariner Optimax 75 hp (two-stroke) and a Honda BF75 (four-stroke) from the web-sites of the manufacturers (I chose the Optimax because that is what we have on our boat). The graph below shows the fuel consumption figures for those engines with a range of boats – red ones for the Optimax, blue ones for the Honda. (Note that this is fuel consumption, the inverse of fuel efficiency.)
Up to about 3000 RPM there is very little difference between the two types of engine. Between about 3000-4000 RPM, it looks like the four-stroke consumes a bit less than the two-stroke, but at higher revs above 4000 RPM, the two-stroke is using less than the four-stroke.
In normal use, a range of engine speeds would be used, so my guess is that the differences between the mid- and high-range consumption figures would cancel out, and there would hardly be any difference between the two. If both engines are used at WOT continuously however, it would seem that the two-stroke might be even more efficient than the four-stroke!
I know that it is not much of a sample with just two engines, and also the weight of the boats used in the Honda tests seem to have been slightly heavier than those used in the Optimax ones, but I was just wondering if other forumites have found this in practice?
