SandpiperCornwall
Hi all, wonder if you can help.
The tension spring on my old but otherwise well made Gibellato lifting outboard bracket has broken and I am trying to find a suitable replacement spring in stainless steel.
I have tried local outboard suppliers and even spring manufacturers but to no avail. (I even bought a replacement bracket but the quality is just not as good and I'd rather fix the old one).
The tension spring I need to replace has the following dimensions:
Length is 120mm unloaded
Length is 235mm loaded
Wire gauge is 3mm
Diameter of coil is 25mm
Gap between loop and body of coil is 7mm
Photo attached - each end has the same loop but you will see that one is broken off.
Any ideas of how to source a replacement? Thank you!
Wire gauge is 3mm
