111KAB
I have an old (1984) Mariner 4cyl outboard which is running perfectly. I recently had to replace the battery (used for starter, tilt and trim) and I now think I purchased the wrong type of battery insofar as the one I bought was basically a car maintenance free/sealed battery. I bit of research indicates this is possibly the wrong type of battery for this engine (???) and I should have bought a wet cell one.
I think I have 'cooked' the battery - on high idle the stator is delivering 16 > 19 volts - quite normal I am told and had I used a wet cell battery it would (if fully topped up) been able to cope with this overload. Whilst I know I have to replace the battery again I want to ensure I do the correct thing as I understand a sealed battery can be incorporated if a 12v regulator (20 amp ???) is linked in. It would seem sensible to me to link this in anyway and then I am 'covered' whatever battery is connected. I would therefore appreciate some help....
a) Does the foregoing sound correct? I have only spoken to a couple of people ~ they are convinced they are right and whilst I have no reason to doubt them another opinion would be nice.
b) If correct where do I get a regulator/stabiliser from and what amperage is required? Is there a spicific wire I should be splicing into?
Thanking you ~ KAB
Thanking you ~ KAB
