ghilliedhu
I am considering buying an old ( mid 60`s) fibre glass yacht . She was heavily built and the gel coat was stripped and 7 coats of epoxy applied about 10 years ago. She has been out of the water fo 6 years.
Is is worth appliying more epoxy at this stage?
Can I just strip back to the epoxy applied in 1994?
If so what is the most efficient way of stripping the hulll back to the epoxy?
Will there be an effective chemical bond if I do so?
There is no sign of osmosis on the outside of the hull but is there a possibility that osmosis might in evidence under the epoxy and if so is this a problem? I ask because I noticed a few blisters about the size of a thumb in the bilges.
Any advice greatfully received.
Regards David
Regards David
