Open CPN for Android
Two versions in he app store. I have the free one on a new Lenovo tablet. Works OK, but scrolling and zooming is as slow as hell.
Just looked at the app store and see there are now two versions, so not now sure about paid or free, I use the lower version.
There was a guy who got annoyed because it wasn't free and complied and released a version. The paid one from Dave register is the official release and much more likely to be updated.
I too have a lenova tablet but when I try to download the free app it tells me "not suitable for your devise
The paid one is well worth the small amount you have to pay for it.
The Android version finally went live on the Play Store last summer.
Since then, there have been about 8 updates.
It is now quite stable.
I use a combination of BSB (KAP) raster charts, CM93 (CMAP) vector charts and a load that I've georeferenced myself.
All the charts "quilt" themselves as onto the screen required - even a mixture of raster and vector charts at the same time.
The most recent ones that I've done myself are based on images from Google Maps Satellite.
The idea is that you can zoom right into a bay and see the sea bed.
Then simply switch back and forth to actual charts.
In fact, the paid Android version has a switch to Google Satellite images as standard but it needs an internet connection so might not be much good at anchor.
My Google charts are stored within the Android device and also show waypoints, tracks and the ships position.
Here are some screen dumps - Ibiza - showing the idea.
Note these screen dumps are from the Windows version - OpenCPN will run on Windows, MAC, lots of flavors of Linus and now the Android.
On the boat, I've installed a ships PC which feeds its display everywhere.
Hence my database of charts is common across all my devices.
Note also the purple lines are previous tracks.
Sound like the perfect setup mike
How did you link the other monitors ?
Unfortunately, they were all linked the hard way - separate feed to each one - lots of wiring.
When we took delivery of the Princess, she was taken to Swanwick where all the factory electronics was stripped out.
A Raymarine G Series was fitted - The G Series is a Glass Bridge Nav system where each display is, in fact, a monitor.
The Raymarine inelegance is provided by a separate control box (two in our case) which feeds to each display.
Each "monitor" has a range of buttons which select the various feeds.
So, we had the PC's feed connected to each monitor.
Simply pushing a single button switched from the Raymarine nav system to OpenCPN on the PC.
I also fed other feeds to each of the monitors - docking cameras and satellite TV etc
When we are cruising, the PC (OpenCPN) runs in parallel to the Raymarine system.
The PC gets its data from the ships nav system (AIS and GPS) but can also "upload" routes etc onto the Raymarine nav system.
Although I've never used it, it is possible to get OpenCPN to control the autopilot.
Sounds complicated but, in fact, it is all really simple - a single push of a button.
Been running it for about 8 years now.
EDIT
Here is a pic of one of the monitors - an external one in bright sunlight.
Note the display is OpenCPN showing how good its AIS is.
Having a ships PC fed everywhere is a great benefit - there are lots of useful apps that can also run on the PC at the same time.
For example, I wrote an audio logging system that "speaks" the information that needs to be recorded (Lon, Lat, SOG, COG and time etc) every 30 mins.
Anyway, back to the OP
The Android and OpenCPN is a great addition to planning - uses the same charts as the ones on the boat.
hi
are you saying you can use the charts from the OpenCpn on Windows on the Android devices?
I didn't think the Android OpenCpn could read the Windows Opencpn Charts?
That's what's held me up using it on Android, not being able to get UK charts like the ones from Visitmyharbour and use them on the Android.
Mike
hi
Mike
I installed the OpenCPN app on my Android tablet then copied over my charts from my PC to my tablet. It works perfectly.
Richard
