Oops a scratch
itsonlymoney
21 Jun 2003
Hi
I have a small ish. scratch on the Bow and six or so indents in the same area, probably an anchor and not done by me I hasten to add. My plan is to clean the area and "dig" out with a dremel if required, then use a gelcoat filler applied with a plastic scraper. My question is this. How fine a sand paper will I require to leave the least marks and will I be able to hand polish with a T'cut or similar. Or will I have to use a rotary polisher.
Thanks in advance of a reply.
Ian
<hr width=100% size=1>Play the best game you can with the cards you've been dealt ! ! !
BrendanS
11 Jun 2002
Tesla in Space
a previous thread will give you just about everything you'll ever need to know about gelcoat repairs <A target="_blank" HREF=http://www.ybw.com/cgi-bin/forums/showflat.pl?Cat=&Board=mby&Number=248744&part=1>click here</A>
<hr width=100% size=1>Utinam logica falsa tuam philisophiam totam suffodiant
itsonlymoney
21 Jun 2003
Thanks Brendan
Thats a very helpfull thread
Ian
Medskipper
20 Dec 2001
Somewhere in the Med!
Dont forget to very carefully with a fine wet/dry paper remove all traces of polish before filling the area. This will stop the filler falling out and help it to adhere properly in the area around the damage.
I didnt read all the replys to the other thread, but in my experience you should finish with G3 / farecula (not sure if thats spelt right?) keep rubbing gently and the result should look professional!
Barry
<hr width=100% size=1>I just want to retire with my boat to the Med!
