MapisM
Actually, I didn't say that STW does not change: even in my first contribution to this thread, after saying that "STW remains constant", I also specified that it can decrease, proportionally to the slip increase - if any.You also said STW will not change, and I'm afraid that is never correct. STW will fall because prop slip increases - the amount is pretty small of course.
Now you are saying that this effect is "pretty small" while I said "marginal (if not meaningless)".
We are slipping into a semantic rather than a substantial disagreement, I reckon...
Unless you accept what that folk said about a boat gaining 2+ knots at constant rpm after cutting the skier rope, because 2 knots out of 30 or so can neither be called small nor marginal.
The only adjective I can think of for such theory is ridiculous, and I'm afraid I could only agree to disagree with anyone who buys it.
Sorry, but aside from disagreeing on the two "aka", it's the "only factor" which is very misleading imho, and this isn't just a semantic matter.if RPM stays constant then the only factor affecting that force is AOA, aka lift, aka prop slip.
In fact, I can't think of any reason why a boat cruising at a steady P speed should necessarily change its AoA depending on its load, unless that load is unbalanced.
What happens when a boat is heavier is simply that she sits deeper in the water, which in turn means a larger wet surface and a higher drag, even if the AoA and the prop slip does not change.
Btw, if the additional load would be seriously unbalanced towards the bow, the AoA could even decrease, hence reducing the prop slip, according to your "aka" above. Not that I think such effect would be meaningful, mind.
And as I'm sure you'll agree, the wet surface/drag/fuel burn would all increase, regardless of the AoA, anyway.
That said, I accept that load (even if balanced) can affect significantly a boat behaviour/AoA during the D to P transition, or while cruising at a borderline speed, which could be just enough to keep the boat steadily on the plane when light but not when loaded, but that's yet again another matter...
