skyflyer
A few months ago I bought my first boat as sole owner, having previously owned a one third share in another - both US built Catalinas
I have what i guess is their “standard’ arrangement of the time (1996) namely two batteries, each 180Ah and a "1-Both-2-off" rotary switch with a "Fly-Tec 20-3" mains powered charger.
The previous owner never went near shore power (well almost never) so when we connected everything and looked at voltages, I noticed that the charger is “unwell”!
It delivers 15.8V to the batteries which is way too much. I think the charging regime from the Fly-Tec is supposed to give about 14.8v initially then reducing to a lower voltage and eventually even a lower float charge. (this seems to be the 'norm' for wet lead acid batteries elsewhere, anyway)
So - is a replacement needed, or is this likely to be repairable - I feel probably not!
Perhaps more to the point, technology has moved on a lot in the intervening 20-or-so years since the Fly-Tec was state of the art, (it was probably designed in the early 90's) and this leads to several questions:
1) is a 20 Amp charger still what’s needed. More Amps = more $, so maybe a modern charger will do the same job on lower amps. Or maybe I need more Amps?
I know the 10% rule, but don't understand if this applies to the total battery capacity (as a bank) or each individual battery, if charging one at a time?
2) Should I be charging both batteries together, or one at a time. If one at a time would a VSR (Voltage Sensing Relay) be a good idea so that one battery gets charged before the other (I suspect not because surely the output voltage of the charger will trigger the relay, no matter how flat the battery, and both will end up being charged together anyway)
3) On my old (shared) boat the set up - rightly or wrongly - was that the engine alternator charged only battery 1 and the shore charger only battery 2 and if you wanted to cross charge you needed to set the rotary switch to ‘Both’. Is this normal? Is this something I would benefit from changing?
4) The biggest power draw (if engine not running) is probably refrigeration when its hot or the diesel heater in the evening if its cold. The boat is kept on a swinging mooring and so we plug in whenever we can get alongside but often go for two or three days using battery only. There’s normally some motoring to help keep the batteries topped up and we have an Adverc modifying the alternator output but its probably accurate to say that the battery of a sailing yacht will still rarely reach full charge through motoring alone. I am aware that battery life is extended by keeping the battery as fully charged as possible and not left in a state of discharge for extended periods of time, so a smart mains charger that fully charges the batteries as fast as is practical would seem to be sensible. Thoughts on that?
Other threads here speak highly of the Ctek M300 which is a 20 amp charger.
Grateful - as always - for others thoughts and input on this.
