Om636 heat exchanger broken, flooded boat
Ardenfour
7 Feb 2004
Port Bannatyne
Arrived back on mooring today, went down into the main cabin to put the kettle on. Wondered why my feet were getting wet. The floorboards were floating! Ripped off the engine cover and its almost submerged. After pumping it out I fired the engine up and loads of seawater spraying out from around the raw water inlet on the manifold. Part of it had broken off. It appears to be some kind of alloy, is it possible to weld this? It's a Bowman heat exchanger.
penberth3
9 Jun 2017
So you've got something so badly corroded it's fallen apart? Welding won't work.
