stuarttoole
I have an old "handheld" that I have inherited, its about 10 years old.
It has an external antenna and box in between the ext antenna and the unit. I assume that this is a booster it has a red light on.
The problem is I am getting only 2 or 3 satellites logged on and if I remove the unit from its bracket it remains poor which leads me to conclude that the external signal is not getting through.
I asssume that it is a poor connection/not working box . How do I test this?
I cannot go outside with batteries as the unit does not now work without the external power source. I assume that it would work better but could it be another problem?
How does the external aerial transfer its signal to the unit I have tried moving the attached aerial to both the upright and facing down position next to the black plastic lump at the bottom of the bracket that I assume is the terminal for the external antenna.
Regards
Stuart "Sarasota"
Regards
Stuart "Sarasota"
