Hate to be questioning a hundred year old tradition but do we actually need flares nowadays?
I have a fixed VHF and a Portable VHF and for the cost of an Offshore Flare Pack I could probably pick up another Portable VHF as a second back-up.
Logic tells me that:
o I can fix my position with GPS to within a few feet. I therefore no longer need to wave a flare about to let someone know where I am.
o If I am close enough to the shore for anyone to see my flare I will be close enough to use the VHF and call the CG.
o If I am far enough offshore to be out of VHF range then anyone out there who can see a flare will also have a VHF radio tuned in.
Most of us carry enough pyrotechnics to start a war. There must be a risk involved with carrying a load of semi-stable pyrotechnics (50% of which are "out of date") on a boat but does the benefit outweigh the risks?
On the boat all safety equipment (including the flares) are readily available for use in an emergency. At home my shotgun is secured in a double locked cabinet. What are the chances of needing a flare in a hurry compared with the chances of a young grandchild deciding that letting off a firework would be "fun"?
On the other hand if I keep my flares in a double locked cabinet on the boat will I be able to get to them in time if I need them?
Assuming that flares are a necessary evil then how many flares should we carry? The recommendations haven't changed for donkeys years and they were set when very few boats (including commercial ships) had VHF.
If we do need flares then should we carry just one of each type (handheld, parachute and smoke)? OK - if no-one sees the first flare then maybe we need two. On the other hand if no-one saw the first flare why should anyone see the second one, or third or fourth for that matter?
The whole "flare thing" is a real puzzle to me.
Has anyone out there ever used one in anger?
Did it have the desired effect?
Why wasn't a VHF message used?
Has anyone had an accident with a flare?
Has anyone really needed a flare and then found out it didn't work?
Answers on the back of a postcard please to .............
Best regards
Ian D
Best regards
Ian D
