Old Fashioned RED-EX Treatment
Jim@sea
12 Feb 2010
Glasson Dock
In the good old days RED-EX was sold on many forecourts as an "Upper Cylinder Lubricant" and was considered to be essential, and many mechanics as part of a service would put a shot of the stuff straight into the carburettor or even on diesels into the air filter vent (if thats the correct word)
So today after finishing servicing my Diesel Engine I looked at the Turbo and wished I had a RED-EX squirt gun.
So my question is "If RED-EX was still available would my Turbo have benefited from a "Double Shot"
(I was prompted to think this as a few weeks ago I was trying to buy a boat with only 80 hours on the engine and when another buyer went out on a sea trial the Turbo failed)
Skylark
4 Jun 2007
Home: North West, Boat: The Clyde
Where are you proposing to put the "double shot"?
The intake side of a turbo, its compressor, supplies only air to the combustion chamber through the induction system. I would advise against putting anything into the induction as the risk of causing compressor damage is high.
The centre housing of the turbo contains its bearings (axial and radial), its lubrication and its seals (compressor and turbine sides). No reason for an oil additive, just use makers recommendation.
The turbine stage uses high energy exhaust gas to turn the rotor.
In the 1970's I used to run my Lambretta on a rediculous rich mixture of redex. Ah, the smoke and the smell :D Today, redex as a diesel additive mixes with fuel to clean that system. Not the induction system.
sailorman
21 May 2003
Here or thertemp ashore
are getting mixed up with Castrol R
nedmin
12 Oct 2002
north lincs.
When I was in the army we used to put a shot of brake fluid into the petrol on our portable generators.Only did it because it reminded us of the Isle of Man TT races !! (Castrol R )
