Wansworth
Looking at a little señera meter sailing cruiser that has the chain plates bolted to the outside of the hull,hopefully the rest of the boat has the same standard of simplicity?
What? You mean botched together all cheap & nasty likeLooking at a little señera meter sailing cruiser that has the chain plates bolted to the outside of the hull,hopefully the rest of the boat has the same standard of simplicity?
Traditionally rigging was brought down to chain plates bolted thru from the outside,great for grinding grp topsides?What? You mean botched together all cheap & nasty like![]()
There are some considerable merits in that approach - including no penetrations through the deck, a lesser likelihood of crevice corrosion, ease of inspection, and ease of replacement should corrosion be suspected.
Exactly?There are some considerable merits in that approach - including no penetrations through the deck, a lesser likelihood of crevice corrosion, ease of inspection, and ease of replacement should corrosion be suspected.
My Stella's chainplates were bolted to the hull; but they were on the inside & the heads of the bolts were flush with the outside.The chain plates were carefully packed to timber, cut to fit to the clinker planks so they effectively sat on a flat surface internally. All neat & tidy.Traditionally rigging was brought down to chain plates bolted thru from the outside,great for grinding grp topsides?
