Graham_Wright
"swinging" ?
How?
Swinging=moving from side to side.
"swinging" ?
How?
To get the boat moving and overcome the strength and stability of the cradle you'll need the mast top man to get his weight outside of the cradle base (ie: the mast tip well over). Even then he will be trying to lift the ballasted keel to get the cradle to tip over.
It's just not going to happen.
The wind exerts a force on the mast, and thus a heeling moment (moment only - it doen't heel becuase it's shored up)
The human suspended from the top of the mast exerts a heeling force if the mast isn't excactly vertical.
Let's compare the two:
1. wind
Force per unit area, F/A = 1/2 rho * v^2 * Cdrag
Heeling moment integrated up the mast is 1/2 w * L^2 * F/A
Cdrag = 1.2 (super aerodynamic car = 0.3 or so, radio mast typically 1.2)
rho = 1.2kg/m^3
v, wind velocity = 20m/s (40kts - a good gale but not exceptional)
w, width of mast and rest of rigging, so 20cm?
L, length of mast = 10m?
Moment due to wind = 1/2 * 1/2 * 1.2 * 1.2 * 0.2 * 10^2 * 20^2 = 4100Nm
2. Human up mast
Moment = L * T * sin(theta),
where T is weight of human (in N) = 1000 say
theta = list, or angle from vertical = 2.5 degrees say (much less usually I think)
Moment due to weight up mast = 520Nm, a factor of 8 less than that due to wind.
So I agree with the others saying that one does not have to worry about the boat falling over if you go up the mast when ashore: if your boat is well enough supported to survive the winter winds it can take you up the mast.
If, however, the combined weight of the person, plus whatever small heeling moment they contribute, is enough the flex the hull minutely around the top of one prop, then when the person swings the other way, the prop might have been dislodged slightly (e.g. pushed minutely into the ground a bit further) and could then drop away.
2. Human up mast
The practice of shoring up boats is antiquated and not necessary these days.
