single
Thread drift but does anyone use Prolong? They claim they drove a truck across the US with nothing except the Prolong in it.
Oh fighting talk there...... FYI Bukh recommend a straight sae30 lube oil for both the engine and gearbox on my "vintage" DV24 and that is what they get (the engine and gearbox) - no multi grades, no synthetic oils (either semi or full) and no EP gear oils or ATF. - 5 litre sae30 is around £15 or if I buy a 25l drum it is around £60. I think I prefer to follow the guidance of the engine manufacturer rather than some rabid ramblings on a forum.Commercial vehicle/agriculturalt parts distributors as well fuel distributors tend to offer best pricing. Also sticking to correct spec is vital. Talk of straight weight 30 lubes is simply nuts unless you run a mechanical CAT 3116/3126............Vintage tractor guys are generally bunch of know nothing numpties.
Many yachts still run raw-water cooled engines, which are thermostatically controlled to relatively low temperatures, low-mid sixties would be typical.
Very many marina-based yachts run their engines solely to leave the marina, when they hoist their sails and turn it off.
It seems likely that the oil in these engines never, or only rarely, reaches optimum temperature. I would suggest that such oils need to be changed more frequently than the handbook recommends.
If anybody is still running nasty old direct cooled thump, thump, motors on a shoestring why are we actually bothering too much about lube drains??
Because I AM, and have no bottomless money-supply like apparently some do.
Not sure why when discussions arise over lube servicing we always have to be driven by the lowest common denominator of geriactric machinery instead of what the majority have.
Lucky for some, but I suspect there are a lot of boat-owners who carry-on with older engines, because they still give good service having been well maintained and used.
Still not bad with no oil in the engine.Having driven across the States five times I'm not sure that's much of a claim as it's only 3000 miles or so and mostly cruising at 55-70 mph.
I shall carry-on as before, enjoying the lovely job of draining hot oil from an awkwardly-placed sump plug via a stupidly tiny space below the engine into a not-big-enough-to-take-a-full-sump-load-of-oil-container and then be thrilled by the task of wiping-up spilt oil in the engine bilge, cabin-sole, handles etc etc. Lovely way to spend a morning aboard!!
Not a good idea. No matter how hard you try you will not get the last bit of sludge out of the sumpWhat a daft way of doing things!
Get yourself one of these:
Take out the dipstick, poke the probe down the hole, give it a dozen or so pumps, then leave it to get on with it while you do the fuel filters, anodes, or whatever else you need to do. If the flow seems to slow down, give it a few more pumps. You'll hear it gurgling like a kid with a milkshake when all the oil is out (assuming you inserted it all the way into the sump). Remove probe, change oil filter, refill with oil. Take pela-sucker away for emptying via the spout provided.
Simples.
If theres any sludge in the sump you are doing something really wrong!
Lynall
