VicS
"The engine" doesn't exist, much less have a duff thermostat. He's addressing what he regards as inconsistencies in received wisdom.
??? surely the thread is about the Perkins 4108 in the OP's boat and the fact that he has noted that the oil temperature, determined by feeling the oil filter, is unexpectedly low.
The thermostat may be faulty but the OP has not commented on the temperature of the engine itself and the circulating coolant. If the engine temperature is low then by all means check the thermostat but I suspect the oil temperature may be low because the oil cooler is using raw water rather than engine coolant. The oil cooler may be completely unnecessary and could be bypassed / removed
The arguments about TBN are irrelevant cobblers as far as the original question is concerned.
