Tilly D
New Member
I am hoping someone can help me here, I needed the bellow changing on my 2005 Volvo penta Duo prop outdrive, I think it maybe a 290 DPE but cannot be certain, I have owned the boat since new so I have had the bellow changed a few times now, the engineer I have used previously has always removed the full leg in order to do this in the past.
I arranged to have it lifted out and told the marina staff that I was going to get a certain engineer in to do the work who has done the job before, I mentioned him by name and was duly informed that he is not allowed on the marina, I didnt enquire as to why, but I asked if they could recommend one, they gave me the name of one and one of the staff gave me his business card. I arranged for him to come and change the bellow and any jubilee clips that he thought needed to be changed and to generally check the leg over and ring me if he came across anything else that required doing. To assist him I cleaned off all the pins ect and gave them a good spray of oil to hopefully help free them off. I received a phone call from him to let me know he was there, I thought I would have a drive down to pay him.
When I got there he had finished the job, I told him that I had cleaned all the pins and sprayed them with oil, but he informed me he did not need to take them out as he only needed to put the trim helmet back, take the gear cable out and remove the top part of the gearbox, so he said it is easier and that is how he always do it as he said the pins can be difficult to remove. I asked him if the oil was Ok, which he replied it was and topped up. He also changed the jubilee clips on the exhaust as one was broken. I paid him and he went.
I arranged with the marina to put the boat in the water the day after, I came down launch day as I wanted to fit the newly painted props, I noticed that there was oil leaking down the outdrive from the joint were he had split it, I immediately rung him up, he said he would come down in three days as he was away, he said he will ring me when he gets there, well he rung me alright but to tell me he had fixed it and was leaving, I went down thinking I would fit the props and arrange to get it back in the water.
I examined the leg but could not see any of the antifoul paint marked were the gear cable goes in at the back of the drive which you would expect if it had been removed, this made my suspicious that he had not removed the upper gearbox at all to check what I believe to be oil rings, I then removed the dipstick on top of the box, this was showing no oil, I removed the front cover held on by two screws and could see what looked like silicone sealant, it was set and rubbery, I think what he may have done is just loosen the nuts or bolts that hold the upper gearbox in place and maybe squirt some silicon sealant in, and retighten the bolts. I trimed the leg up and the exhaust bellow came off from the outdrive end, on close inspection it was covered in grease obviously to aid him on getting it on, but I would have thought grease would be the last thing you would put on as surely it would make it slippy and easy to slide off, I have now cleaned the grease off and after a struggle managed to get it back in position and tightened the jubilee clip up, I have also topped the oil back up to the correct level. I thought I would leave it overnight to see if the leak had stopped now that the oil would be above the joint.
I went home and sent the engineer an email listing what I have found and asked him if it was now fixed and safe to but back in the water, he has replied and said I had not noticed that the exhaust bellows has slipped off, this was an oversight by me, regarding the oil leak, I can confirm that I have removed the top section again and the oil sealing ring which I have coated with an oil resistant silicone and replaced all parts, I hope this answers your query. I went back the following day and there was a couple of weeps, one from were one of the bolts are and at the rear near were the gear cable goes in, so it is not fixed although it is no where near as bad as a leak as it was. Can any of you experts tell me is it possible to remove the upper unit without taking the gear cable out totally. Be interested in your thoughts, I am going to name and shame this engineer in due time. He is in the Lancashire area. I have also given the marina a piece of my mind and told them to forget charging me for extra time I am now shored up as it is now going to take longer now to get this sorted. I have lost faith in this engineer and have told the marina I am bringing in the engineer I normally use, which they have now agrred too. Sorry for the long post.
