Oil leak from Leg
spike2450
13 May 2007
Falmouth, Cornwall
Hi again
I've just purchased a Bayliner 2452 with alpha one gen 2 leg.
When i trimmed the leg down to start her on the hardstanding with the hose, green oil has leeked from a small hole on both sides of the leg the position is just above the cavitation plate.
I'm guessing that when the leg is raised oil is somehow getting out from the lower leg and when i trim down it is then allowed to seep out of the hole.
Any help would be great.
oldgit
6 Nov 2001
Medway
Hi Spike,you really need Spannerman for this one or perhaps Volvopaul.
Cannot for the life of me think what oil in the leg would be green in colour.
spike2450
13 May 2007
Falmouth, Cornwall
Hi
It's the same oil that sits in the lower leg, i believe from the bayliner forum that the oil is probably leaking from the shift shaft oil seal, i bit the bullet in the end and a marine engineer has taken it away to pressure test, D M Marine in Falmouth who i highly recommend.
pistonbroke
3 Jun 2002
Down South
Mercury High Performance gear oil is green.
