standfirmrasta
Hi,
What do parts 2a thu 9 do and what happens if they fail?
Hi,
One is piston cooling jet relief valve , other is main oil gallery relief valve . There is also a valve inside the sump .
Thanks but i need to know the symptoms of failure please?VP can you confirm if they are worn there would be a resultant loss of oil pressure? And more importantly, how does one actually remove 2A to replace it? It appears to be a rather tight push fit as if it's been put in with a drift
I have oil gushing passed the oil pipe from the sump into the rocker arm and hence out through the crankcase breather.What is the reason behind the post?
Can you explain where i might find that please?It sounds as if the oil gallery relief valve isn't doing its job.
No it’s inside the sump .Can you explain where i might find that please?
Is it in the oil filter housing which i had off today and valves appeared to be OK>
Yes engine rebuilt have a PM going with youNo it’s inside the sump .
Have you rebuilt the engine
