Oil change via dipstick
Never Grumble
29 Sep 2019
England
Martin_J
19 Apr 2006
Portsmouth, UK
The box with my oil change bits and pieces is on board... and it's been a year since I last changed the oil.
From memory, the suction pipe is the same outside diameter as the metal suck out tube on the engine.. I seem to think I have an inch long piece of old fuel hose that fits snugly over both.
I'll check at the weekend... and get a photo
Skylark
4 Jun 2007
Home: North West, Boat: The Clyde
Hi I have just discovered my 'new' engine doesn't have a sump plug. The only way to get the old oil out is suck it out. I have the pump and some plastic pipe. My question is does the suction pipe go inside the dipstick pipe or over the outside Thanks.
I seem to be in a minority so preparing to hunker down in fear of criticism to follow 😭
I put plastic pipe over the dip stick tube to form a seal. I then use my 12v Oil Extraction pump. Engine is 3 cylinder Yanmar.
davidmh
30 Jan 2015
The pela is good but even with warm oils it takes a long time if you have to use the small diameter tubing. on by Bukh I take the dipstick tube off the block and this leaves a bigger hole which the large pela tube goes into.
David MH
