rogerthebodger
I made a quick and dirty video to demonstrate a test...
That is quite interesting.
I note you used a centre tap inverter where the earth wire is connected to the centre tap.
This is very similar to the way that on out door work site safety transformer works where the highest voltage between either the line or neutral is 110/120 volts and I dont think those site transformers have a RCD
Would you do the same tests with a non centre tap inverter. I would like to know how you wire a non centre tap inverter which is more like a incoming shore power line.
