Neeves
The aluminium Spade and Excel anchors consistently perform worse than their steel equivalents in anchor tests, despite their identical fluke areas.
We had a steel and an aluminium Excel No4 and a steel and aluminium Spade, A and S80,m. 38' x 22' catamaran 7t in cruising mode. The Spade '80' and Excel No 4 are roughly the same performance and similar weights. All have ballasted toes, that will obstruct setting as it, the ballast, protrudes under the fluke.
I could not tell the difference between the 4 anchors and the steel versions were relegated to my workshop. I also tested them for hold and their hold was similar.
Of course my assessment is a combination of quantitate testing (hold) and subjective, I only used the steel versions, comparing with the aluminium versions over about 5 years - before I retired the steel versions and used the aluminium versions as sole primary for only 10 years.
If I was buying again - I'd focus on the aluminium versions and recommend same.
If I extend or broaden the 'definition' to include a comparison of the Viking pair of 'ligjtweith anchors I'd focus on Odin, not the original Viking (I think Odin a superior design and engineering).
Jonathan
