Non-slip decks
iBrow
3 May 2013
What's the best way to clean a large area of very grubby, moulded-in non-slip deck surface on a fibreglass deck?
Thanks for any advice you can give!
Hi
We had the same problem with our decks and in addition to several years of grime and bid muck there was green algee and even traces of moss.
I sluced the deck with a 1 to 4 mix of Patio Magic, scrubbed it with a stiff brush, left it for a couple of hours and then went over the deck with a small pressure washer.
appart from a few spots where my scrubbing was iffy it brought both the glass fibre and the trackmark areas like nearly new.
Good luck
Hi
Good luck
Plenty of people do use pressure washers on GRP decks, but plenty also overdo it and open up little voids in the gelcoat. By the very nature of the way they are made the GRP non-slip pattern, be it diamonds or wrinkles, is inevitably resin-rich, and can have minute air bubbles in, which a strong jet from a pressure washer can open up into little voids.
So if you go with the pressure washer use the fan jet not the spinning needle "turbo" jet and not too close, and keep it off any woodwork. Some strong detergent left for a while, a small scrubbing brush and a toothbrush for the crevices works wonders, aided by some oxalic acid locally to remove rust stains.
