curious1
Has anyone overcome the following problem which has suddenly appeared.
My Autohelm ST4000 will not set up correctly when attempting to navigate to NMEA information from my Garmin 152 'Navigate to' function.
The Autohelm only shows 2 of the 3 required fields, ie. bearing, and 000's in the distance to object field.
The display does not show the "turning to port or starboard" field.
An NMEA signal is being produced by the GPS as it is giving a position to the DSC/VHF radio.
Is the problem with the GPS or the Autohelm?
Absence of Cross track error data comes to mind but I have no way of proving it.
