lpdsn
The general rule of thumb is that an NMEA2000 spur should not be longer than 6m. I'm trying to find out what the principles are behind this. Obviously it's a rule that comes from DeviceNet originally.
The obvious things I can think of are that it is based upon are voltage drop and timing of messages, but neither seem to be key.
For example, the 6m is measured from the bus not from the power supply. OK, bus cables are supposed to be thicker so will have a lower voltage drop, but if this were the main driver I'd expect a rule that combines spur length and bus length from power supply to the junction. (I have found formulae that calculates expected voltage drop but my point these aren't reflected in the 6m spur limit.)
Similarly, NMEA2000 devices take the timing from the last transmitter to synchronise their own transmissions. But a quick back of the envelope calculation shows that shouldn't be a problem (as you might expect). And anyway, if this were the reason I'd expect there to be a rule of thumb about how far apart the two most distant nodes in the network are not a rule about spur length that doesn't account for the actual backbone length.
I'm looking at putting a 6.5m spur in at the end of the backbone where that end of the backbone is 5m from the power and total backbone length is 14m. My hunch is to just go for it, but I'd prefer to understand the principles behind the limits first. Any info?
