Plevier
If you are using ANY of the ST 60 instruments, they will work without the Raymarine interface when linking to a device inputting/outputting 0183. I have been doing that for over ten years with no problems. However, once you move to NMEA 2000, or wish to include a Seatalk New Generation (SeaTalkng) item in your system, you will need to get an "Actisense NMEA 0183 to NMEA 2000 converter". I had to buy one of these when fitting a new autopilot last year. Raymarine DO make their own adapter but they readily admitted to me that it is inferior to the Actisense NGW-1 which is the item you need. Google it for further info.
Max.
Please be specific - are you talking about getting NMEA FROM the ST60, in which case it's nonsense to say ANY of the instruments as only the multi and graphic have NMEA out terminals, or are you talking about putting NMEA INTO the ST60, which is not a problem?
If you are actually talking about NMEA OUT from a multi or graphic, have you tried connecting it to a device such as the Garmin plotter with a single ended input using DC -ve as the other connection, or only to well behaved differential input stages, which will work?
The problem is absolutely specific to getting NMEA FROM the ST60 INTO a single ended input.
