TradewindSailor
Epirbs
Thanks to lw395 on this thread I have just read the Australian Maritime Safety Autority's (AMSA) multi-page information on EPIRB. It is very informative and should be read by all ....
http://beacons.amsa.gov.au/usage.html
Cherry picking some of the information, I have the following comments to add to the discussion ..
Although the units are water proof they can be damaged by corrosion and hence rendered useless.This corrosion may not be found by the self-test.
Epirbs with GPS operate similar to those without GPS UNTIL SUCH TIMES AS THE GPS SIGNAL HAS BEEN PROCESSED. This is VERY important as the GPS signals are more prone to failure in bad weather conditions AND unused GPS systems are known to have difficulty finding their position when first turned on as is the case with an EPIRB.
A polar orbiting satellite may take seconds or up to 5 Hours before it receives an EPIRB signal according to http://beacons.amsa.gov.au/gps.html ... i.e. in or around Australia.
I am a great believer in carrying EPIRBS, and the best one I can afford, BUT I also believe that it is VERY important to know under what circumstances they will not work despite the Self-Test indicating that they should.
I also believe there is data available that will indicate the failure rate of EPIRBS when used in emergency situations. I look forward to any informed help on this matter.
