Nina : NO COMMS DOES NOT MEAN NO SURVIVORS - KEEP SEARCHING
TradewindSailor
26 Jan 2007
New Zealand
According to this facebook thread:
https://www.facebook.com/ninarescue
the NZ searches were concentrated to the NE of an erroneous Iridium position. The last position given by the crew looks to be about 150 miles to the West of the Iridium position and consistent with the actual position reports. This would put them on the NW sector of the low pressure system (low pressures are clockwise South of the Equator) and hence they would be being pushed to the N and NW.
http://www.flickr.com/photos/art-on-fabric-by-sylvie/9365965749/
http://www.flickr.com/photos/art-on-fabric-by-sylvie/9365967257/
A lot of speculation has focused on that there have been no comms since 4th June. No comms is simply that: no communication. It doesn't mean that there are no survivors, and it certainly doesn't mean that Nina had sunk.
Nina had the Iridium phone (non-gps), a SPOT device that reported simple messages including the position, an Epirb, and a VHF.
The VHF is of use only as a line of sight comms ..... up to 17 miles yacht to yacht, more to a ship, and much more to an aircraft (75 miles?).
The Iridium phone had been good up to the 4th. The last message was sent to the Iridium system on the 4th, but not found until about the 25th June from my recollection. Could it be that the Iridium phone was faulty after the 4th? Could the last text message have been stored in the phone only to be sent when it was next turned on? I don't know. One thing I am absolutely certain about is that the Iridium phone was not a reliable means of communication, and an even worse position indicating device. Why was it used by the authorities to base a search when better information was at hand?
The EPIRB. I understand that the EPIRB was a non-GPS unit. No EPIRB emergency signal was received from the Nina. The EPIRB would only be used in circumstances where a MAYDAY would be initiated. If the NINA was floating and navigable, I doubt if the EPIRB would be activated. BUT at sometime between the 4th June and now circumstances must have deteriorated enough for the EPIRB to have been activated. So why no EPIRB signal?:
1 It is possible that the EPIRB could not be reached if they had to abandon NINA quickly
2 The EPIRB may not have generated a signal that was accepted as a bonefide distress message and hence ignored by the system.
3 The EPIRB could have passed the self-test but still failed to operate correctly. The self-test is purely internal to the EPIRB. No transmission is made at all, so it is not a test that checks the entire system.
4 It would take up to 'a few hours' according to the USCG for this type of EPIRB to generate a position fix into the system. I understand that if the position fix is not completed, the emergency message is not sent .... I am awaiting confirmation on this.
5 The antenna would not be checked by the self-test as there is no transmission. There have been failures of antennas in the past ..... cracking of the rubber antenna casing leading to corrosion of the internals. No antenna .. no message.
6 The condition of the battery is not properly checked during the self-test. The batteries generally produce the required voltage even though they may be short on capacity. They are known to self-discharge at much higher rates in warm weather .... and the NINA spent a lot of time in the tropics at around 30 deg C, more if the unit housing was heated by the sun or engine. There are incidences reported on the internet where EPIRBS have failed to send the message due to bad batteries, or have only operated for a few hours .... see 4 above.
7 I have been unable to obtain any data from the authorities where vessels that are fitted with EPIRBS have been lost without an EPIRB message being received, or any other case where EPIRBS have been activated and the message has not been received.
8 What are the effects of weather condition on EPIRB transmissions, especially when operated in bad conditions from a liferaft or in the water?
SO : NO COMMS DOES NOT MEAN "NO SURVIVORS"
I hope the authorities can comment any of the above, particularly if I have made a mistake.
Most of all, I hope the crew are found alive and well. Remember there are cases where survivors have been found after 117 days adrift in a liferaft...... and that the Spirit of Baltimore went down with her EPIRB, but some of the crew were rescued several days later by a passing ship.
The New Zeeland and Australian search and rescue organisations are among the best in the world. They know their patch better than anyone else.
They will continue the search as long as there is a realistic probability of finding something. They will conduct the search based on the best information they have available gradually expanding the search area to cover all probable areas based on several possible routes.
The loss of communication just gives a place to start.
I'm not certain that is the case. I can't find the reference now, but when I was investigating trackers such as SPOT and the rest, I came across a website which allowed you access to test signals received from EPRIBs. That information also included the position. The website was advocating the use of EPRIBs as a poor man's tracker. I never used it so I can't comment on how it worked. (There was a charge, by the way).
From the USCG site :
http://www.navcen.uscg.gov/?pageName=mtEpirb
"Testing EPIRBs
406 MHz EPIRBs can be tested through its self-test function, which is an integral part of the device. 406 MHz EPIRBs can also be tested inside a container designed to prevent its reception by the satellite. Testing a 406 MHz EPIRB by allowing it to radiate outside such a container is illegal."
As many other owners of EPIRB's you are living under a false sense of security.
"Testing EPIRBs
Interesting. That would suggest that the TEST function does, in fact, radiate a signal. Never heard of the requirement to test in a 'container', nor ever read it in a manual.
AFAIK, and this may not apply to all epirbs, the test function will radiate a short burst, which is detected by internal circuitry.
So everything up to the antenna is tested.
Of course, the battery may fail or many other possible faults.
SAR aircraft would also pick up the 121.5MHz signal, but that is using the same antenna, battery and microcontroller.
They would probably pick up AIS but that relies on the ship's power.
Then there are possibly SARTs in the liferafts?
Until the area around the new last known position has been covered VERY thoroughly.
The few SAR pros I know would not call off a search all the time they thought there might be someone alive out there. If they've stopped searching respect their professional expertise and their consciences and don't try to outguess them. They have far more met, drift, and search pattern data available than us self-appointed 'experts'.
Many thanks for that information. That is my understanding too.
This is hotting up over here at the moment. Can you please give a reference/url about this for the record?
I must say the workings of the EPIRB are generally taken on good faith. I hope that there will never be a time that the SAR authorities will refuse to conduct a search unless an EPIRB signal is received.
Agreed and I'm glad I don't have to make this decision myself!
I don't have anything definitive to hand but:
http://beacons.amsa.gov.au/beacon-testing.html
might help?
The test in the container is not the self-test. This is a full on test of the EPIRB's transmission that is DEFINITELY NOT intended to be done by Jo Public. I think the SAR authorities carry it out, and some researchers have in the past.
I think this sort of test is carried out when EPIRBs are made, and when they are refurbished. Also for 'type approval'.
Routine inspection is done using the self test features.
If there are survivors, they have gone some weeks without outside help, they could be many miles from the last 'known' position.
Australia has good radar coverage of the sea around it. I very much doubt there is a (intact, floating) 70ft schooner they cannot find.
I'd like to be wrong.
I find all this iridium position talk worrying. Iridium does not really do 'position' unless you phone someone and tell them what your GPS says.
This test is carried out by MCA radio surveyors on commercial fishing vessel EPIRBs, and probably all commercial shipping beacons, as part of the 'radio survey'.
Thanks for that. Yes, I am aware of the discussion and the one about EPIRB registration, and of course the discussion on facebook which is getting lots of exposure.
Provided everyone is aware of the different discussions, I think this particular thread is very useful in that it discusses one of the fundamental beliefs that I have heard far too often, namely that "since there was no communication since 4th June that there are no survivors". Some people say that the failure of comms from the EPIRB, Iridium, and SPOT is proof that something catastrophic happen to Nina and her crew and there is no point in continuing the search. I say that failure of any one or all of these devices does not indicate that there are no survivors.
