That aint true, both "Spottys" got hit by sailors who clearly couldn't.
I have a question, Gary/Lisa, was this an organised race?
I think you misunderstood my post - I wasn't referring to Gary's situation with dinghies, I was referring to your general interpretation to Rule 9 where you seemed to be saying that Gary's boat couldn't navigate safely outside of the channel and that all sailing boats must avoid him on that basis. I was just pointing out that Gary's boat wouldn't qualify throughout the whole of the Hamble as a vessel that can't navigate safely outside of a channel - it can - and that some sailing boats can also claim rights under rule 9.Steady l'escargot. First, rule 9a imposes an obligation on the sailboats to keep to starboard if following the channel and rule 9d tells them to keep out of the way if crossing the channel. Those two circumstances cover all the bases don't they? I mean you're either following or crossing the channel, or both (ie diagonally), I think. The obligation in 9b applies to Gary but I do not see he is in breach of it. He must of course observe the overtaking-vessel-gives-way rule if he comes up astern of a slower sailing dinghy but I don't think that point was in dispute (though correct me if I'm missing something there).
I should add ref my post above that I am talking Colregs only. I don't know about special Hamble rules. If there are any local rules that give a different answer then of course I'll eat my words and Gary and I will have to fall back out of loveAlso, I'm kind of assuming Gary has to be in the fairway - I just don't have enough on depths and so on to comment. But in applying that part of the rule remember there is the word "safely", which is probably within the skipper's reasonable discretion to determine.
You didnt really think I would miss this did you
In a nut shell a sailing boat isnt allowed to impede a mobo in a narrow channel
Hold your course and remember you have an equal duty to avoid a collision, once in the latter stages of avoid a collision situation you are usually exempt from the speed / wash restrictions found in most bylaws . :encouragement:
Agreed. BTW, I edited my post while you were typing, but no worries I think.I think you misunderstood my post - I wasn't referring to Gary's situation with dinghies, I was referring to your general interpretation to Rule 9 where you seemed to be saying that Gary's boat couldn't navigate safely outside of the channel and that all sailing boats must avoid him on that basis. I was just pointing out that Gary's boat wouldn't qualify throughout the whole of the Hamble as a vessel that can't navigate safely outside of a channel - it can - and that some sailing boats can also claim rights under rule 9.
I disagree, as you say it is your opinion but I think it is you seeing what you want to read and not what is written - not me. To say you think they should be rewritten would suggest that you want them to say something different to what they do say. I think that ColRegs on the whole is actually quite cleverly worded.With apols for my pedantry, but that isn't correct. The Colregs as a whole are (imo) a terribly badly drafted set of rules, full of ambiguities and in need of a thorough re-write, but you have taken it further and seen what you want to read, not what is written. The definition of a mobo involves "propelled by machinery", and in that case it's clear the draftsman didn't intend that a vessel isn't "power-driven" merely because it is in neutral. But the definition of "under sail" uses different words: it requires that any propelling machinery is not "being used" and doesn't at all use the words "propelled" or "propelled by machinery". You may argue, but you cannot say for sure as you do above, that an engine temporarily in neutral isn't "being used". I'd say that it is "being used", fwiw.
The point not quite reflected in what you write there is that although Gary can only claim the benefit of 9b if he is big enough, we are mostly dealing here with 9a (from the arrows on the picture) and in that circumstance the question of "big enough" doesn't arise. 9a applies to everyone (except 90 degree channel crossers, but that's not what we have here) whether a kayak, Laser or superyacht. Again, see Deleted User's post 56 on the MBM-demise sticky thread.
As a general comment from admittedly limited exposure to the Hamble but in quite a large tricky boat, it would help if the sailing community were educated that the power-gives-way rule is fully trumped by rule9, and therefore there are plenty of scenarios where sailboats are not stand on. It felt to me like many sailors only knew the power-gives-way rule. That is a bit of a broad brush comment of course, but I think it's fair
With full respect to your view, I disagree. They're far more clumsy than clever imho. Remember, most of the rules existed as practices or rules among seamen long before colregs. All the colregs did was clumsily write up what folks were mostly already doing.I disagree, as you say it is your opinion but I think it is you seeing what you want to read and not what is written - not me. To say you think they should be rewritten would suggest that you want them to say something different to what they do say. I think that ColRegs on the whole is actually quite cleverly worded.
I don't know where it is so established but would be happy to hear. This is yet another of the ambiguities I complain about above. You are making quite a leap to say that it is established that machinery that is "on" and running doesn't give a boat all the advantages of a mobo and that the draftsman didn't intend the vessel then to be treated as a power driven vessel. Furthermore, if you look only at the wording not the intention then note that "in use" isn't qualified by "for propulsion". An engine running to charge the battery is "in use" in the ordinary sense of those 2 words. As I say, we are in ambiguity-ville here, though fortunately most of us manage to keep out of trouble anyway (despite the rules, not because of themI think it is well established that an engine for propulsion in neutral is "ready for use" and not "in use". By definition it's purpose is propulsion and if it isn't being used for propulsion it isn't being used for it's intended purpose. A sailing boat with it's engine running is still sailing just as a motorboat at anchor with it's engines running is still at anchor, neither are motoring
The term "propelled" is quite unambiguous and has been used deliberately as opposed to using something like "engine" or "motor" and Rule 3(b) & (c) are quite specific. I don't think there was any intention to define "propelling machinery" that isn't being used for "propulsion" as being used.
Yeah but that get out as you call it will not win the day. A sailboat with an engine can turn it on to overcome the "practicable" problem - there is no exemption from 9a due to merely wanting to sail. If the sailboat is so small it has no engine then it's a dinghy and can tack upwind up the channel using only half the channel's width so leaving loads of room for Gary. (Just to disclose, I am very much a sailor as much as a mobo-ist. I have helmed Mirabella V, a Mirror, and much in between@ 30 to 100 feet. I own a Laser and can definitely tack it up the Hamble leaving enough space for a 30 foot mobo to get byThe "get out" for sailing vessels in 9a is "..as practicable".
...which brings us back to the stupid guesswork in this rule. How can a guy who first saw the other boat 3 minutes ago know better than its skipper? Why should the rules ask him to decide?giving due regard to vessels who qualify under that rule. Vessels that don't, have an obligation
Yup. Well, I agree the sentiment behind your broadbrushing, but come to think of it, I think perhaps few mobo-ists are knowledgeable* enough on the switch to rule 9 when in channels and therefore arguably don't assert their rule 9 rights enough. Everyone is taught the general collision rules without being reminded they are sort of "open water" only.I think likewise, as a broad brush, there are motorboaters who believe that they have rights under 9b when they could navigate safely outside of the fairway.![]()
Can you provide a translation please? Oh & there are still no (& never have been any) col reg situations where anyone has "right of way"
Yup, I think so, but happy to be corrected if I've missed something. It is another shortcoming in colregs that rowed/paddled boats have no place in the "power gives way to sail" hierarchy so you don't know where you stand, but things like rule 9a apply to all vessels so must apply to kayaks and rowing boats (though not PwCs - there's another glitch). Only if the kayak in question is actually in the fairway or channel of course, rather than in the shallow edges among the bushesAre you sure about the kayak? Serious Q!
Yeah but that get out as you call it will not win the day. A sailboat with an engine can turn it on to overcome the "practicable" problem - there is no exemption from 9a due to merely wanting to sail. If the sailboat is so small it has no engine then it's a dinghy and can tack upwind up the channel using only half the channel's width so leaving loads of room for Gary. (Just to disclose, I am very much a sailor as much as a mobo-ist. I have helmed Mirabella V, a Mirror, and much in between@ 30 to 100 feet. I own a Laser and can definitely tack it up the Hamble leaving enough space for a 30 foot mobo to get by). In the rare case of a big sailboat with no engine then I agree with you, but that wasn't Gary's or OP's case
Possibly not if a collision occurs, rule 2 probably infers an obligation to use an engine to prevent a collision but only when it becomes clear a risk of collision exists not simply to make something practicable or "just in case". I think that may be an example of you reading into the rules something that people helming large boats, and probably many motorboaters, would like to see - that sailing boats use their engines for their convenience, possibly because in some cases they simply just don't understand sailing. There is no obligation under ColRegs to do so for such a purpose - not under rule 9 or any other rule in the ColRegs, although I accept it does sometimes come into local regulations but not in the Hamble AFAIK..
That is unavoidable. He doesn't need to know better than the skipper, just the same, so we have to presume a certain level of competence amongst people on the water - although that is a big ask. When there are two parties, both are needed to make a decision on the application all of the rules. Ultimately, if it all goes wrong, a third party who wasn't even there will also make a decision on the rules and the original two parties will be held to account for their decisions
I think you could probably say the same about sailors - although then you get into the whole minefield of defining a fairway, channel and narrow channel.Personally, I am basically a lazy sailor and can't be bothered to short tack my boat up somewhere like the Hamble - too much like hard work
*BTW I should admit that I only bothered to read this in detail because last year I found myself doing the Hamble for first time in many years. The rule stuck in my head because I had the luxury of >20m which meant I was exempted from 9b. So I was (broadly) free to impede others while they were obliged not to impede me. All I had to do was stick to the stb side of the channel! Nice position to be in, though I didn't abuse it (much)
Overall I still think the ColRegs are a pretty good solution to open water and they have been revised and updated over the years to introduce changes considered necessary - the powers that be must still consider them fit for purpose. I do think it questionable though whether they are strictly applicable to a situation such as that which Gary found himself in or whether they are intended to be applied in such situations but, I suppose in the absence of any specific local regulations, there is nothing else.
I think the bit often forgotten about ColRegs is that most of the contentious rules only come into play once a risk of collision exists - there is plenty of opportunity for common sense and courtesy before that happens and to prevent the need for them to come into play.Fascinating reading this but then again, I am boat less :-/
A couple of things pop into mind here which do not support either side the debate one bit so feel free to pass over my ramblings and get on with it
Regulations are fine but surely it's is common sense and courtesy which should prevail in these situations however, I realise that common sense in not "common" and courtesy is thrown out the window when there is a race to be won
In my previous sport it was common to catch a slower car on a special stage or indeed be caught as the slower car. There is no regulation for this scenario but the sporting thing to do is get out of the way - fast. It is an adrenalin fuelled sport so if you are not courteous you can expect an accidental tap on the backside![]()
I already suggested what I would do in the OPs situation but for the life of me I can't imagine what I'd do in Gary's case. He managed it well IMO as although he didn't receive courtesy he used his to diffuse the situation. I think if I was there I would have just followed the tacking boats until I could pass and ignore the others. I can't see where my rally driving experience could have helped me here![]()
