pcatterall
Before the masts go up I am considering replacing the mast head light. Currently it is an old fashioned affair using the old standard 10w bulb.
I guess I should look for an LED light ( I could consider an LED bulb in the old fitting but have a feeling ( cant check) that the old fitting was a bit suspect.
One consideration is the size of bulb; I guess that I could fit an LED giving me more ( lumens/candle power) than the old bulb and still use less power.
What are other folk doing/using?
The current lamp is on a short stalk with 3 screws to fit to the mast top so I guess a similar fitting would go on more easily.
Yacht is 10m.
Thanks for the usual good advice
Yacht is 10m.
