xeitosaphil
After much work over the past few months I have now got most things working properly and have now managed to fire up one of last winter’s projects, the new Fridge Freezer cool box conversion. It is quite small ( about 35lts ) due to the amount of insulation provided, but will be suffice for my needs and hopefully the benefits of the extra insulation will be worth the reduction in volume.
Once down to temperature approx 30mins ( empty ), the freezer sits @ -7 Degrees C, the fridge goes down to +3 degrees C which is a little low but with more food in it, and a little more tweaking it may go a little higher. The Danfos BD 35 f cycles once every 30 mins and runs for 7 mins at a time. 4 mins @ 3amps and 3mins @2 amps – is this about right?
It is controlled by an air temp thermostat as recommended by the Tech guy at Penguin frigo Refridgeration.
If I have worked it out right on the figures above, it will use about 28 ah over a 24 hr period?However my ammeter doesn’t read milliamps’ so 3amps could be up to 3.9amps and 2 amps could be up to 2.9amps which could make the drain up to 38ah over a 24hperiod?
Having run it for 24 hrs it reduced my 220ah domestic bank from 86% to 70 % which I equated to 35ah (16%) rightly or wrongly, which could account for the difference between 28ah and 38ah based on the different possible ammeter readings.
Re charging the battery up again to 86% using the engine, it took 1 1/2hrs roughly @ aprox 1400 rpm with a 90A alternator / Adverc, only possible as I was attached to the berth with the engine in gear.
I thought this is not a scenario I could achieve if anchored somewhere, so I need to supplement my charging with a solar powered panel.
Having looked at panel out puts, would I be right in assuming that a 100w solar panel will probably give me aprox 5.5amp charge over a 6 - 7 hr period i.e. 35ah a day on a nice sunny day? This would offset the drain from the frdg/frzr and with another flexi panel of say 20w, may cope with most of the usual usage.
Would a MPPT 10A Solar Regulator be that much better than a PWM regulator and worth the extra expense?
I have put some links to a few panels which may be suitable but would be glad to hear of others if better suited or even cost less, one does have bi-pass diodes included so should have better performance with shading issues.
As Prices are about to rise I thought I would get in before they do. I also need to replace my existing Unisolar 11w flexible panel in front of the spray hood on deck as it is only showing 1.5v across the two wires so must be shot. Not sure whether to go with another flexi panel as mounting a fixed panel would be a problem with access to the boom when attending the Main, I did wonder if it would be possible to fix one in front of mast on coach roof but would rather not if possible as the cable length to the batteries would be in excess of 5mtrs.
Any comments gratefully received.
Solar panel links
http://www.ebay.co.uk/itm/100W-Mono...caravan-boat-NEW-/350556163623#ht_4116wt_1141
http://www.sunstore.co.uk/12v-100w-Monocrystalline-Solar-Panel.html
http://www.ebay.co.uk/itm/NEW-100W-...UK_Gadgets&hash=item3a81db1776#ht_4804wt_1018
The one I favour at the moment is the first link as it has bi pass diodes and seems to have reasonable guarantees and a sturdy frame as it will need to be fitted on the push pit on moveable fixings. It also says it is 18-19% efficient which seems to be better than the others, but I wouldn’t know how to determine it?
Solar panel links
