Catalina36
N/A
4hp per ton is the standard. Overpower it and the engine will never work hard enough, it will soot up and and the bore will glaze.
If they are the same engine, take the 10. On the basis that your cruising revs will be 2000rpm, unless you want a screaming engine, the bigger engine will be a waste of money, and running an engine at half revs or less will do it more harm than good.They are the same engine! The 10hp is the 14hp (actually 13.5hp) restricted to (IIRC) 3,000rpm instead of the 14hp's 3,600rpm.
You may get a larger output alternator as standard with the 14hp.
I had a Beta 14 in a heavy-ish long-keel 23 footer, and that was ample. I'd be tempted to look at the Beta 16hp (also a twin) and only 5kg heavier, or even the 20hp, a 3 cylinder, for the Twister and its 60% greater displacement.
Even in a sailing boat there are times that you need a decent engine with sufficient power. The question therefore was whether the 10hp did a decent job of driving your boat. Did it get you up to 6 knots or thereabouts. Could you punch into a stiff headwind? The extra weight of a bigger engine u=is unlikely to be more than 20kg or thereabouts. In the context of a 5 tonne yacht, thats a trivial penalty that likely could be cancelled out by getting shut of some of the junk that you like the rest of us will have on board.Hi - I'm looking at a new engine for my 28ft Twister. My 10hp Volvo MD is coming to the end of its life...
At first I was thinking of going up to 15hp, but, wondering whether that's foolish, given extra weight/size etc...
After all, it is supposed to be a sailing boat...
Just wondered if there was any consensus/strong opinions on what's the best amount of power per size of yacht...?
Thanks,
Crisp
Is that true? I’m guessing all modern boat manufacturers would disagree. Your average 5 tonne 30ft JenBenBav will come with, what, 20hp minimum I would have thought? My 1991 31ft 3 tonne boat has It’s original 27hp Yanmar that runs beautifully 29 years on. 10hp on a 5 tonne boat doesn’t seem much to me.If they are the same engine, take the 10. On the basis that your cruising revs will be 2000rpm, unless you want a screaming engine, the bigger engine will be a waste of money, and running an engine at half revs or less will do it more harm than good.
Prop size.Let's say your 2000 RPM figure is correct and that most of the time you run the 14hp engine at 2000 RPM, how is that any different to running the 10 hp at 2000 RPM, if they are the same engine ? At least with the 14hp engine you can open it up some more if you need to.
I would be hesitant to get the 3 cylinder Beta 20. I think it vibrates way more than a simple 2 cylinder one.![]()
My 3 cylinder Beta 25 is definitely smoother than the old Volvo 2002 twin was (although to fair they were separated by 30 years in age) .I'd disagree, Admittedly, I have no personal experience of the Beta 20, but most three cylinder engines are very smooth, like their cousins the 6 cylinders, It's the 120 degree crank angles.
I went up from 10hp (1GM10) to 14hp (Nanni N2.14) and the extra power is very nice, although the new engine had a lot of teething problems. The boat is 26' LOA, long keeled, 4 tons; with the Yanmar she'd do 4.5kt flat out and 2kt into a 20kt headwind while with the Nanni she'll do 6kt and 4.5kt into the headwind.Hi - I'm looking at a new engine for my 28ft Twister. My 10hp Volvo MD is coming to the end of its life...
Not all twin cylinder 4 strokes are 360 degree cranks, but it may be the case for diesel boat engines.My 3 cylinder Beta 25 is definitely smoother than the old Volvo 2002 twin was (although to fair they were separated by 30 years in age) .
Any straight twin cylinder 4-stroke will have both pistons moving up and down at the same time won't it ?
I kept the same prop in the hope that going from 2.4:1 to 2:1 would spin it fast enough to absorb the extra power. On the whole it seems to have worked, though I may have a tad knocked off the pitch some time.Whatever you go for, do do some research to find out what propellor you'll need to transfer the power to the sea.
