Need to Reef
johnalison
14 Feb 2007
Essex
I don't carry a genoa, just a 110% jib. Generally, this means reefing the main first but just occasionally I might reef the jib first if I am going to have to short tack, as in a river. If I had a genoa again I would also reef that first, for the reason that if I reefed the main first, I might then need to reef the genoa as a second reef and that would be at higher wind speeds. Reefing the main can be done at any wind speed but it becomes increasingly harder for a jib/genoa.
ithet
27 Mar 2009
UK, Hamble
I think an over-large genoa can also cause weather helm if it causes excess healing - through waterline and keel effects?
This is definitely the case with my yacht which has a massive bulb keel. I reef the 130% Genoa first when it is too difficult to wind in. This reduces heeling and weather helm. The main gets reefed when we still can't keep heel below 20%. I would also add condition of sails and point of sailing to the list of variables, the old baggy Genny we used the other week caused us to head off and heel so much it had to be reefed hard. The new flatter genny allows closer angles and can be rolled up to be like a blade. A further variable is main aspect ratio. My low aspect masthead rig means that my full main effectively has a reef compared to more sporty fractional counterparts, which is the reason I did not go for a blade.
Biggles Wader
3 Mar 2013
London
Also depends on which point of sailing. Reefing the genoa always results in significant loss of shape/performance for me so I try to keep it fully deployed as long as possible. Main gets reefed first.
Beaten to it above!
Channel Sailor
5 Mar 2009
Portsmouth (UK)
Another point to consider, if the wind is expected to increase further, then reef the most difficult or time consuming one first. Agreeing with the above: Depends on the boat and the rig design/proportions. if going upwind then try to keep your genoa luff length long and a good shape for windward work. Though mainsails with a large roach or even a flat top also is something to factor into the decision. On my yacht the 1st reef in the Genoa is OK for some relief but a proper reefed effect on the yacht comes with the 1st reef in the mainsail. It is a fractional rig.
Stemar
12 Sep 2001
Obviously, it depends on the boat but, all things being equal, if I have to go to the mast to reef the main, I'd rather do that first. If I've got the genny down to a pocket handkerchief and still need less sail, I really don't want to have to go forward to reef the main.
byanyothername
28 Mar 2018
It will obviously depend upon your boat.
Personally, after some experimentation, I
always reef the main first. My Westerly Centaur is much happier balanced with full Genoa and one reef in the main than vice versa. But YMMV.
Bathdave
4 Apr 2012
jersey, CI
This is what I concluded on our boat, after a couple of years of thinking I should reef the Genoa first
my sequence now goes
- ease traveller
- 1 reef in main
- 2 reefs in main
- reef Genoa
we have a 115% Yankee cut genoa,
this sequence keeps the boat better balanced
grumpy_o_g
9 Jan 2005
South Coast
Also depends on the sea state and point you are sailing. If you are running downwind in a heavy quartering sea then dropping the main first, never mind reefing, may be the best option unless you have a silly-sized IOR rules- driven Genoa.
