Need help identifying Diesel motor!
alexsalm
24 Jun 2014
Hi Everyone!
I just got given a tired sailboat with an inboard diesel engine. I don't know too much about them unfortunetly, so was wondering whether anyone can make heads of tails of what make/model this one is, and if its worth resuscitating. Before the battery and masterswitch got stolen right before I got it, it turned over, aside from that, I'm new to diesels. Thanks!
Heckler
24 Feb 2003
Hi Everyone!
View attachment 43463View attachment 43464View attachment 43465View attachment 43466View attachment 43467View attachment 43468
Its blue,therefore a Perkins, confirmed,by the casting. That number Perkins 103 - 1? indicates that it is the base perkins that volvo use for their MD20XX series.
Stu
Heckler
24 Feb 2003
It says AR on the block, which would point to it being a Perkins 4.421 - This guide to Perkins engine identification might help http://www.j-a-enterprises.com/PerkinsEngineGuide.htm
The Perkins numbering system that you are quoting. 4 indicates the number of cylinders and the other 3 numbers indicate the cubic inch capacity. So for example the 4.108 was a 4 cylinder of one hundred and eight cubic inch capacity! The pic is of a 3 cylinder engine! Count the injector pipes!
Stu
Tranona
10 Nov 2007
See my explanation of the Perkins numbering system, that is the Perkins that VP base their mD20XX series on
S
Yes, I know as I have one, but the marinisation and some details like fuel pump, engine mounts, heat exchanger are different from the Volvo version. Think my 3 152 bit was wrong as that (from memory) is an old Massey Ferguson tractor engine - but could be wrong on that as well!
Stork_III
6 Aug 2002
Here and There
Stu
Perkins 103-10?
Heckler
24 Feb 2003
Sorry, was getting in to the "pedant" mode!
VP did their own heat exchangers as did a bloke that used to go around the boat jumbles.
Stu
