prv
Sooner or later I'm going to want to mount an antenna for the Navtex (currently just using it as nav data repeater). The boat is largely free of extraneous things strapped to the outside, and I'd like to keep it that way. So I'm thinking of mounting the antenna high up inside the hull, such as inside a cockpit coaming. I understand that as it's a lower frequency the need for height is much reduced compared to VHF etc.
This would probably involve having the antenna horizontal rather than vertical; does this matter?
Alternatively, I'm sure I read about someone who connected his receiver to a chainplate bolt, to use the rig as a large but chaotic antenna. Is this worth considering, or a completely daft idea? Note that the unit in question has a powered tuner box but a "dumb" antenna, so I wouldn't be bypassing any necessary amplifiers or applying a voltage to the rig.
Any general tips on antenna positioning, or how to easily tell the difference between a good setup and a bad one?
Cheers,
Cheers,
