trowell
Greetings from Ynys Mon.
Does anyone know what fittings e.g. spacers/washers make up the assembly for the lever with the white plastic cover on it. This lever is the one that, I think, locks the paddle shaft. It faces the front of the boat and is about 40-50mm in length. There is a large spring on the other side of the bracket and a joins the top of the paddle shaft
I have the lever, a washer and the split pin to secure it in place but it looks as though there should be something else perhaps on which the lever can pivot. Alas the manual does not show any helpful drawings.
Any help most would be gratefully received
Thank you
Tony
Thank you
Tony
