It doesn't vary. But on a chart using a Mercator projection, the vertical axis is more and more exaggerated the further north you go. This is why Greenland looks massive on maps of the world. The scale on the right is the one to use.
You are technically right, but to avoid the problems caused by the distortion of the earth the Nautical Mile has been standardised as 1,852 meters or 6,076 feet.
What I guess trays is refering to is the fact that, on a small scale chart, a nautical mile is not the same length at the top of the chart as it is at the bottom. That is because of the distortion inherent in the Mercator Projection. The greater the latitude the greater the scale. That is why Greenland looks so huge on Mercator Charts of the Northern Atlantic.
Wright improved on the projection developed by Mercator and wrote a book which provided tables and explanations. The following intuitive explanation is his. Make a globe out of a spherical balloon. Place it in a larger glass cylinder. Blow it up slowly so that it first touches at the equator. Continue blowing it up slowly. Each point on the balloon globe is blown up until it is pressed against the wall of the glass cylinder. Higher latitudes are blown up more. The final result is a Mercator projection. Wright explained that the scale factor varied with the secant of the latitude.
If you would like to know more, look <A target="_blank" HREF=http://www.geocities.com/yachtretreat/>http://www.geocities.com/yachtretreat/
Was and is still generally considered to be the length of 1 minute of arc on any great circle of the earth. Because the shape of the earth is not a perfect sphere that is not a very sound definition for exactness. Most nations standardise it as an International Nautical Mile being 1,852 meters, which is the figure proposed by the International Hydrographic Bureau. One cannot escape the metric system even when it is most unexpected.
Actually, metrics has an even greater bearing. The distance from the equator to the pole was arbitarily chosen as 10,000km hence the derived length of the metre.
This yields a distance of 1851.852 metres to an arc of 1 minute (== 1 nautical mile), which is rounded by convention to 1852 metres.
don' u mean one minute of arc. (60 miles to a degree, 60 minutes to a degree = 1 mile/1 minute, 60 seconds to a minute =1/60th of a nm =101feet)or our my calculations wrong?
Surely a cricket pitch length between the stumps is the breadth of the Saxon strip-acre??? ie 22 yards exactly.
At the poles a nautical mile is 6,108.8' and at the equator it is 6,046.5 feet ... It's all because Napoleon's mathematicians didn't know the difference between a sphere and an oblate speroid.
Latitude increases to infinity at the poles in theory !!!! But anyway if you look at a chart in different regions you will see a difference in the masurement assuming same scale. Even on the same chart you can measure the lat scale at the bottom ..... now place the same dividers not changed at the top scale and see the measurement ....
<hr width=100% size=1>Nigel ...
Bilge Keelers get up further ! I only came - cos they said there was FREE Guinness !
If it really were we wouldn't have to worry about local datums! It's more akin to a King Edward potato in reality, but the spheroid is the closest we come to a mathematical model.
I was told that the metre was based on the wavelength of a particular matter .... can't remenber what exactly what ... but never heard about the equator - pole theory ..........
