Rhylsailer99
I just went to remove it inside the boat to clean the wheel, at low tide. The top has cracked now and I am worried when the water level rises at 3am , will it leak through the top ?
ISTR the paddle wheel sensor body is a solid moulding down at the bottom end at the wheel, there shouldn’t be any water getting inside it to leak out of a crack at the top end.Threaded cap is fine its the top where the wire comes out is cracked.
I bought a dummy and will keep it on the boat as spare just in case. I will clean the paddle wheel next time from outside the boat as I don't think they are great when being removed from the inside.ISTR the paddle wheel sensor body is a solid moulding down at the bottom end at the wheel, there shouldn’t be any water getting inside it to leak out of a crack at the top end.
As you have found it dry this morning, It wouldn’t give me sleepless nights.
