NASA Instruments: buzzer voltage?
Poignard
23 Jul 2005
South London
Can anyone tell me please, what is the operating voltage of the buzzer (bleeper) that comes with NASA instruments, eg Clipper Depth Sounder.
The NASA part number is SM523-BUZZER
Refueler
13 Sep 2008
Far away from hooray henrys
Poignard
23 Jul 2005
South London
VicS
13 Jul 2002
If you have an old one it may be marked on the back
Alex_Blackwood
19 May 2003
Fareham
In take it you have the manual ? I know it does not give voltage of the buzzer - but shows it wired to the green and black wires in mine.
I have to say that mine hardly ever sounds when it should !!
I have a feeling its an Active 12V ....
If you need a new one ...... Spare alarm buzzer - Clipper, Target and Cruiser Depth - Nasa Marine Instruments
Probably "Bog Standard 12 volt" Most buzzers of that type, Piezoelectric, have a large voltage range. Load of 3-24 volt, for example, available on line.
AngusMcDoon
20 Oct 2004
Up some Hebridean loch
There are some where all you need is a DC voltage applied to make them buzz, & others that need a driving circuit that oscillates. Datasheet will need to be consulted. The last commercial device I worked on the electronic engineer had specified the wrong type - all you get is a click.
Refueler
13 Sep 2008
Active vs Passive.
Most applications like this use the ACTIVE type ... built in driver.
