Bosun Higgs
N/A
thinking of installing one. any comments / experiences?
one minor benefit in testing masthead lights. You can see the current drain go up (or not) as you switch lights on. Morgan
Not very good if you have multiple batteries and multiple earth returns.
It is difficult to imagine why you cannot fit a monitor, although you are the one in the best position to judge.I've got one of these sat in a box. I tried to fit it but you can only fit the shunt on the negative side of the circuit (I checked this with NASA). Not very good if you have multiple batteries and multiple earth returns.
If I could have fitted the shunt on the positive side then it would be fine.
I could do with selling it if anyone is interested.
It does seem to be a nice piece of kit though.
Why not just fit a 12v panel meter from ebay less than a fiver from China/Hongkong
There are ones available that will read volts/amps ok not as complex as BM1 but a fraction of the price.
Ive just installed one today, am well pleased with the ease of installation, ease of setup etc. Just one point Vic, you can connect the orange wire to the starter battery to monitor the voltage only.Be sure to install exactly as the instructions say !
Might be a good idea to read the instructions and wiring diagram downloadable from the NASA website to be sure you know what is involved.
Read the recent thread concerning the BM1 .. it appears some people have some problems
A little more expensive and working on different principles but also consider the Smartgauge With no shunt it is easier to install and it will also give you a voltage reading on the starter battery as well as fully monitoring the house battery. The Nasa BM1 only monitors the house battery.
I agree Vic, mine is a 4 battery bank, I had taken note of other debates about where to put the out going cables and had put them in the middle of the bank. I just reset them to the end battery so that they were daisy chained and put the lead to the shunt off the end battery. My solar panel in and inverter out (which bypass the main switches, fused I may add!) I put on the "upstream" side of the shunt so any in and out is measured.It is difficult to imagine why you cannot fit a monitor, although you are the one in the best position to judge.
Why not post a diagram of your battery wiring and see what suggestions the forum can come up with. It sounds like the sort of challenge we enjoy.
I think that's a recent improvement. It's not mentioned in the on-line manual or shown in the online wiring diagram but it does ring a faint bell in the back of my mind.Ive just installed one today, am well pleased with the ease of installation, ease of setup etc. Just one point Vic, you can connect the orange wire to the starter battery to monitor the voltage only.
Apologies if you have already seen it or knew about it but in the tech info section of the Smartgauge website there is quite a bit about interconnecting multiple batteries into a common bank so that voltage losses on the interconnecting cables do not result in the charging and loading being unevenly distributed between the individual batteries.I agree Vic, mine is a 4 battery bank, I had taken note of other debates about where to put the out going cables and had put them in the middle of the bank. I just reset them to the end battery so that they were daisy chained and put the lead to the shunt off the end battery. My solar panel in and inverter out (which bypass the main switches, fused I may add!) I put on the "upstream" side of the shunt so any in and out is measured.
Stu
Do what it says in the box, dont second guess it or you will be on here like the other guy asking for more advice!I am about to install one of these and am surprised at the short length of cable supplied for connecting shunt to battery.
Does anyone actually use this in the purpose described in the manual as the shunt would have to very close to the battery?
I am hoping to position the shunt quite close to the negative bus bar and therefore use the supplied cable for this connection and my existing cable for battery to shunt.
Does anyone see any issue in this approach?
I followed the instructions to the letter, it is superb for the price.
Stu
