cmedsailor
The red wire on the NASA BM1 battery monitor has a fuse connected to it. Anybody knows what size (amp?) fuse is it?
20mm 1amp
+1
I think the BM1's a good piece of kit for the price but that particular fuse-holder is a cheap piece of carp, mine would not make a good electrical contact so I ended up replacing with a better fuse holder, no problems since.
Exactly! I need to replace it with a better fuse. Appart from this the BM1 is fine.
I have taken to replacing most inline fuses with water resistant rubber blade fuse holders, the ones I use have an LED which glows if the fuse has blown which is a real bonus. I also now use blade fuses for panels which incorporate a small LED that glows when it's blown.
those are very sensible, do you have a link pls
There are the chaps, even the tails are tinned and they will handle up to 30a fuse http://www.ebay.co.uk/itm/WATERPROOF-30-AMP-Blade-Fuse-Holder-LED-BLOWN-WARNING-/170588198911.
Link to seperate fuses. http://www.ebay.co.uk/itm/5-Pc-LED-Intelligent-Car-Plug-In-Fuse-Set-5A-25A-Light-Up-When-Blown-/310347096402?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item484220e152
And after all the comments regarding this NASA BM-1 fuse over many years on the YBW forums one might think they would have taken notice. Ship spoiled for -lets say- 10p at most??
20mm 1amp
I just wish you could get inline fuse holders that you can wire up, rather than with tails.
I was horrified to discover 20mm fuses on my boat, totally unsuitable. All replaced with automotive type, mostly in fuses boxes. I just wish you could get inline fuse holders that you can wire up, rather than with tails.
