AntarcticPilot
I work a bit with wrought iron. Nightmare... The gates are from the turn of the last century and are entirely screwed or rivited. Welding is tricky and not strong.
But, for nails or bolts in a boat, probably very good. It does not rust like steel and since much of what I look at is well over 1OO yrs old, Corrosion is limited.
I'm speaking only from an interest in ancient metal-working technologies, and no practical experience at all! Isn't forge-welding the usual technique for welding wrought iron? Obviously difficult, if not impossible "in-situ", but should result in a strong result - after all, most ancient sword-blades are forge-welded, and wrought iron was originally produced by effectively forge-welding a sintered block of "sponge iron" to make a billet of wrought iron - early smelting furnaces did not reach a high enough temperature to melt the iron. Indeed, that's the origin of the name "wrought" iron! The spongy, slaggy block of iron from the smelting was simply heated to the welding point and hammered to a) weld the particles of iron together and b) express slag and impurities.
As you say, wrought iron is usually very resistant to corrosion; there are some very ancient examples - see https://en.wikipedia.org/wiki/Iron_pillar_of_Delhi, for example.
