oGaryo
When will you get it ?
....bit of a thread drift if ever there was one but happy to oblige with a response
she's in a bit of a mood mate so not for a good while yet, I'm hoping for some time in 2013...
thanks BM the 1st
Resourceful lots us boaty folk... cross bearings are coming out a treat with this method.. benefits of using a large adjustable spanner on the bearing cap end is the vice doesn't have to open so far and you can see the bearing cap coming through.. using a large socket obscures it. the large spanner is purely for leverage and the smaller socket obviously used to push the bearing through. no heating required, the extra pressure from the heavy duty vice is enough to push it through.
The tools arrived 30 mins ago so have come off the work lappy to give them a quick go and boy what a difference!
Went for the most stubborn UJ that had bent the handle of the heavy duty vice and laughed in the face of the C Clamp / blow torch approach... Seriously, the thing was stuck big time but the combination of the C Press (substantial bit of kit, weighs a ton) and the Impact Driver pushed the UJ out the Yoke like a knife going through butter.. no stress on the Yoke at all.. Very impressed and will allow me to move the UJ Cross Bearings to and fro to hopefully, eventually, get the end caps orf.
Lesson learned that's been experienced so many times before.. stop fannying around trying to save a few pennies and get the right tools for the job Gary!!!
a bonus is the larger hole on the C clamp is slight wider than the hole in the yoke that the end cap goes in to... no need to mess around with sockets as the end cap isn't blocked by anything, it protudes out and through the C Clamp
Will take a video of the kit in use tonght.. work beckons
onwards and upwards
Apply a small portion of curry, then dose heavily with wine, I'm sure with a bit of manipulation normal operation will soon be restored.
Good news Gary!
The right tools for the job make all the difference..
Sounds like you will be on the water for the Bank Holiday!?
Should be but just need to co-ordinate a few things with Tom, my work and footy to get the Gimbal Bearing replaced... not out the woods yet with the UJ's as Tom is going to send some up once I've identified the exact type to send and these end caps are still playing hard to get.. That said, it's all going in that direction now... Trim Tab actuator is sorted and I've foudn the fault for the inoperative speedo so when she goes back in, all should be back to working as it should be![]()
Yup, its all about juggling!! Good luck
I think (hope) we have identified issue with my leaky gearbox, if correct just an O ring within the shaft coupling and a small job to replace which Paul (volvopaul) is doing next week.... so fingers crossed!
HI BOTH GARY & JAMES.......glad some progress for you both on your respective mechanical gremlin killing !!!!!..... just for info (sorry for thread drift), but i wont be down untill after the bankholl !!!!! *$%$££^&%^... or words to that effect!!!!!!..but will txt if things change..just remember while the weather is as crud as this, YOU AINT MISSIN NUFFIN !!!!!
tried that one mate but just made an awful mess of the UJ's and the end caps still wouldn't shift... nice idea though![]()
As you know, I meant Deb![]()
Got a single female visitor, staying with us, so yes I would be up for a beer.....thanksnext challenge is getting the cas off the UJ's my cheap pair of mole grips aren't cutting it so going to buy a pair of Irvin Vice Grips later today and get them out with those hopefully... determined to get the UJ's out today so I can make progress getting the drive put back together.
Will likely be down this weekend if you fancy a beer
I think this whole "my outdrive is buggered" is just an excuse to buy tools.thanksnext challenge is getting the cas off the UJ's my cheap pair of mole grips aren't cutting it so going to buy a pair of Irvin Vice Grips later today and get them out with those hopefully... determined to get the UJ's out today so I can make progress getting the drive put back together.
I think this whole "my outdrive is buggered" is just an excuse to buy tools.![]()
You haven't seen her yet....... but she is a hairdresser, so quite usefulI'll rescue you from the fair maiden Roy![]()
