oGaryo
You haven't seen her yet....... but she is a hairdresser, so quite useful![]()
spooky, I need my hair cut
I'd have been tempted to buy the £99 upper unit on Ebay you posted a link to and use the non rusty input shaft from that with new bearings. When they are not rusty, they come out very easily!
Graham
Bloody hell Gary , that needs fixing ........................................................
Do you know anyone ?![]()
Good interesting stuff Gary, and steady progress, well done. Takes me back to my Triumph Herald days when I had all sorts of UJ/rear diff issues. Several good smites with a 2lb Brummie screwdriver were the order of the day. Parts were easier in those days, from the local tat yard, or straight from the Triumph factory
Following your tribulations with interest in case I suffer the same problems.
will keep the updates coming... shame there's not a mercruiser scrap yard around these parts
Aren't those caps hardened ? If so and you use one as a drift and belt it with a big hammer, they could shatter !
that trunnion and cap was not damaged recently too look like that.
Not sure if the new caps will have nylon retaining rings fitted, if not, be really careful not to let a needle drop and slide up inside the cross. A wipe around the inside of the cap with some grease tends keeps the wayward ones in the right place.
Hope it all goes well with the reassembly. I am not sure if we are down at the weekend but if we are and you are in need of a pair of hands to help relocate the drive on the stern, feel free to give me a shout.
cheers
Paul.
cheers
Paul.
+1 with the grease.
