Bojangles
Where did you get 15psi from data sheet just says
For best results bring the two dry, coated surfaces into contact within 10 minutes of the adhesive films becoming ‘touch dry’ and press together over the entire bond area. Apply as much pressure as possible by hand. Sustained pressure is unnecessary.
I don't think the vacuum is necessary, when using this method it is really to provide not only a tight clamp on the subject but to provide curing time for the glue (ie pva). With contact adhesive the glue is really cured before the 2 parts are brought together, therfore the grip is almost instant but when used on a large flat surface you need to apply local pressure (ie roller, or another piece of very flat wood and a heavy hammer, if you have a good base). If you are using the roller method I would overlay with 4mm ply and roll over the top of this, preventing tram lines from the roller.
For the edges, unless you are really good with blades/files etc, you'd probably be better using a laminate trimmer/palm router. Edging is another matter, if these are currently 2mm (thick) plastic wood effect edges (on doors), they are probably best removed before you apply the veneer and renewed at the end. Your veneer supplier will probably stock this.
Good luck, I'm enjoying the thread, it's good to see a great boat improved in so many ways.
