TonyBerkshire
Red wire possibly was going to battery +ve but your pic does not quite show that terminal to see if there has been something connected. Really need to see where it goes to, possibly the same cable to the right of "2" in pic 2?
Have a check at both the battery and under the rubber caps on the isolator for a broken ring terminal that may have belonged to that wire.
I personally wouldn't go reconnecting it anywhere until you've had a good look at what it could be and checking what does and doesn't work on all the boats systems. If the boat has a bilge pump there will be a level switch to activate it, test that to see if it works, ie lift the switch and the pump should kick in. The picture below shows a typical setup, bilge pump is on the right and on the left is the level switch that activates it (basically the arm floats when the bilge fills with water, a bit like a toilet cistern, and activates the pump. Simply lift that lever and it should set the pump off. As has been said this is probably the only permanently wired connection. There may also be a manual bilge pump switch on the dash.
It may also be for something that has been removed so see if you have any stray wires anywhere in the dash/engine bay. You can always check for continuity using a multimeter which would be a useful tool to buy when you own a boat.
There appears to be no inline fuse which should always be quite near the battery/isolator. It was a good call above that it is probably for something that draws quite a few amps, maybe the wire went to an inline fuse originally, strange there is no fuse there, trace it back, it may go to a mini busbar/distribution box. Need a further away pic really to see if it's anything to do with all those relays.
That red wire if it goes straight to the battery could be for a bilge pump or radio memory, whatever it is for it should have a fuse inline if not taken from the isolator switch output side.
It looks like it has just corroded off, see what don't work to start with and if it starts working when dabbed on the battery +, if a bilge pump it will likely have a float switch somewhere close to the pump so won't do anything unless there's water in the hull (or lifted with a finger to test), if the stereo won't hold a radio station when powered off and back on that will be the memory feed.
An isolator key is just that, brand is pretty irrelevant but the ones with a brass pin are less likely to break than a plastic pin, keep a spare on board hidden somewhere.
Yes standard battery isolater key as has been described and the red thin wire will just be to some piece of equipment possibly now removed. Or once you have the red key see what does not work. Have you a depth finder, fish finder or chart plotter on the boat
As for the wire, it probably came off the battery isolator so the circuit becomes live when you throw the switch. You'd need to trace that wire back or see what isn't working to find out what it was for. It might have been for something that has been removed in which case you wont want to liven it up!
Edit: I see the answer has already been posted above!
Posting more photos to try and establish where the wire may go below....
