Scotty_Tradewind
Stating the obvious... dont forget to disconnect the battery supply before playing with the solenoid
Good luck
S.
Good luck
S.
...BTW Sidepower recommend tapping the solenoids with a light hammer when they wont work.
if solenoids are OK its brushes
good luck with what ever you end up calling it...
As an aside, bowthruster also needs a name. Any suggestions welcomed.
This must be a record - 25 replies and nobody has said that you should learn to handle the boat and not rely on a bow thruster!!!!!
I was secretly betting on when that might come up! Definitely a record.
Yes, I agree with your school of thought, and don't actually tend to use it; but might as well have it working if it's there, and I'm not so 'hardcore' I'd completely refuse to use it if ever in a bit of a sticky situation.
Sorry - that isn't my view at all - anything that makes boat handling easier is a good thing - there are times on my smaller boat where I would love a bow thruster.
So previous owner installed a bowthruster, a new Vetus 75kgf, around 2007.
Bought the boat (Colvic Victor 34), bowthruster worked fine.
A couple of months ago bowthruster started working in one direction only, with a mechanical clunk noise heard when trying to get it to go the other way.
Now it doesn't work in either direction; press the buttons and nothing.
What's wrong with it? A couple of people have said the solenoids; likely? How can I fix it? (My dad will help - he's good with electrics and mechanical stuff.)
Silly q Jellie ... but why not fix it a couple of months ago when it first went 'clunk' in one direction?
if breezy, I use the noisy sucker...
And what about the Bow thruster?
