My bowthruster doesn't thrust my bow...
jellyellie
2 Jan 2008
www.jellyellie.com
So previous owner installed a bowthruster, a new Vetus 75kgf, around 2007.
Bought the boat (Colvic Victor 34), bowthruster worked fine.
A couple of months ago bowthruster started working in one direction only, with a mechanical clunk noise heard when trying to get it to go the other way.
Now it doesn't work in either direction; press the buttons and nothing.
What's wrong with it? A couple of people have said the solenoids; likely? How can I fix it? (My dad will help - he's good with electrics and mechanical stuff.)
As an aside, bowthruster also needs a name. Any suggestions welcomed.
jordanbasset
31 Dec 2007
UK, sometimes Greece and Spain
Similar to what happened to mine, turned out to be the the solenoid. Just a question of taking it apart and cleaning up around the contacts. When putting it back together had to be careful to make sure the contacts were correctly seated
Huttoft
29 Nov 2005
Lincolnshire coast.
Shock tactics
Have had the same sort of symptoms with mine. Found that it was the mechanical parts of the solenoids were sticking. Stripped them down, cleaned them up, (including contacts) re-assembled and left running OK. When it happened first time with me I was in a tight spot manouvering in a strange to me marina so I asked my daughter to "shock" the thruster into obedience by hitting the tops of the solenoids with the wooden shaft of a hammer. Sounds a bit drastic but worked until I had time to strip the job down and overhaul.
jellyellie
2 Jan 2008
www.jellyellie.com
Thanks @jordanbasset and @Huttoft, will try and give that a go with the help of mon pére. (The solenoid cleaning, not hitting with a hammer!)
@Bav34, that's rubbish, and far too obvious :p
I wish I was more of a rugby fan though, as 'prop forward' is genius...
Greenheart
29 Dec 2010
Sir Shovalot?
Shouldn't that be Sir Senokot?
Oh!! No, that's a bowel-thruster, isn't it. At least, so I'm told. :D
Greenheart
29 Dec 2010
Great heavens alive! You mean that...you're a...a woman?
I thought the name was that of your boat.
I thought these fora were gents only. :D
Greenheart
29 Dec 2010
I believe someone in London, in the 'twenties, did design a 'divided skirt' to enable ladies to bicycle and suchlike. But at sea? :eek:
