[176172]
There isn't any 'keep having to keep changing the switch setting' making the manual system sound work intensive, it is not as you would describe it. I agree it has inherent dangers if used incorrectly, but so does the galley cooker, or the autopilot or the many other things we do on a boat, if done thoughtlessly.They're in the business of fixing boats, not enjoying the use of boats. The biggest drawback of the 1-2-Both switch (apart from frying the alternator if you turn the switch off accidentally) is having to keep changing the switch setting, with the associated risk of leaving it on the wrong setting and flattening the start battery - which I suppose is where Sea Start get involved. Just having two simple on/off switches and a VSR (or low-loss splitter) makes for the easiest possible operation. Arrive at the boat, turn both switches on, use the boat, then turn both switches off when you leave the boat. No risk of a flat starting battery. No risk of a well-meaning crew member messing up the 1-2-Both switch setting.
