Perplexed
New Member
My yacht is poorly equiped with cleats. So I want to put an additional cleat amidships on either side.
The plan is good....but the application has caused problems, and for this I ask for your help, please.
My hull is twin shells, with foam filling between - but not where the cleats are to be!! Which I found when I drilled my first hole!
There is just a hollow space, about 50mm deep. Drilling further goes down against something very solid, and if I forced the issue I am certain my hole will not come through into the cabin, so I am unable to fit a backing plate and bolt through the cabin deckhead.
So, it seems as though I have to find way to fix something inside the empty, hollow space between the layers. I have epoxy, but there is nothing in the hollow space to contain it, or hold it.
Has anyone suggestions how to get around my problems, please?
